daltonvol wrote:I've had my '14 Rogue for a little over 2 weeks and am curious as to whether or not I'm experiencing "normal" symptoms from it.
First, after driving it any distance it seems to idle rougher than my previous Rogue. The engine idle is audible (which it wasn't in the '13 model), and sometimes I hear a knocking noise that seems to come from the passenger side of the engine compartment. Both of these seem to be worse if it's been a longer and/or higher RPM trip (i.e. interstate versus highway).
Also, I believe I'm feeling a lot more vibration in the brake/gas pedals and steering wheel in this one as compared to the '13. Even if I'm resting my arm on the console I can feel it. I thought maybe I was just being picky/paranoid, but over the weekend my wife even noticed it from the passenger seat.
Has anyone else noticed these things? I'm going to make an appointment at a fairly local Nissan service department to let them check it...but I know that lots of times their MO is to says it's "normal"
Thanks!
Just wanted to update you, yesterday on the drive home at stop lights I would listen, and I heard a slight knocking sound like you are describing, if I had the radio on at all I couldn't hear it, it was very slight, and it sounded like it was coming from the passenger side of the engine. You might be able to pick it up on recording with special equipment from inside the car, but not with just any every day recorder most likely. Maybe from the outside you could.
Anyway, my guess it is normal. after having our 2013 Accord a few months we were waiting in a parking lot for some friends to show up, and I kept hearing this noise... at first I thought it was birds outside... finally realized it was the AC. You can always have the dealer look at it for peice of mind, and if you do find something is wrong let me know because I have it to.
