14 Pathfinder Hybrid LED tail light swith?
rafalk79
Car: 2013 Nissan Pathfinder Platinium
Did anybody try to switch LED tail light from hybrid to non hybrid Pathfinder. I bought lights but connectors are different. Any help? thanks.
dskywalker
Car: Pathfinder 2014
Hi, I'm looking to do the same. I already ask to the NISSAN technician about the possibility to do that and is just matter to find the connector Santech/3 in pigtail. once you get it, you can connect to the original wire line, but I was wondering about the voltage, but they told me it should be the same and no problems with that.
This is for the main lamp, for the other you should try to find the connector.
Please let me know if this works, I will try this weekend.
regards.
Slumpert
Car: 1997.4 Pathfinder
I have not pulled a newer one apart but the tail lights are usually on a secondary harness. Even if it doesnt have the same main harness connector, it would have all the right tail ones
dskywalker
Hi. Still looking for the pigtail connector for the tail light, next the images of the connector. if some one can give a clue where to get, will be very appreciated.
Is the smaller and white one.
crtirado
Car: 2013 Infiniti JX35
2012 Infiniti M37 Deluxe Touring
2015 Nissan Pathfinder Platinum
Hi! Where you able to do complete the swap?
ekanson
Car: 2014 Pathfinder
Hi Did anyone do this mod?
