1305 code-- Fuel Control Module
915max
Car: 1998 Nissan Maxima
I need help with this one..... so I checked my engine codes through the side of my ECU and it threw out 1305-- Fuel Control Module. - I checked the ohm readings off of the fuel sending unit---> Good- Fuel Pump working properly- Checked all injectors using a stethascope except the one under the manifold-- (good)- REplaced fuel filter
dont know what else it could be-- I havent checked the fuel pressure from the filter to the rail. I was also thinking it could be the fuel pressure regulator.
I've noticed the car tends to hesitate during acceleration at times around 3000-4000 rpm range... Also in the mornings, the car tend to bog out when taking off in first. I havent had the chance to check up other things but has anybody encountered this problem??
This problem started occurring about 3 or 4 months after I put in the Technosquare ECU.
maxhopper
Car: 02 Maxima SE 6spd
I would go ahead and check the fuel pressure. If that's not it, I'd have to say it's something with the Technosquare program. Was it set up for bigger injectors, or anything like that?
915max
The ECU wasnt actually, and I take back what I said.... the bogging on 1st did occur prior to the ECU.
I also had noticed a while back that when I'm driving on the freeway in 5th gear and I stomp on the gas pedal... it tends to have this studdering feel to it momentarily and then it takes off. Reading on another thread about the MAF, my car has similar symptoms. I'm gonna check the MAF
I forgot to mention but I re-installed my stock ECU and the only code its reading now is 0902-- rear O2 sensor, which is normal because I have a test pipe.
I'm thinking just to get the 3.5 swap and forget about the problem...LOL
