Dori Dori wrote:Seems odd they'd read low across the board. Maybe you do have a thicker HG although IDK how much lower it should read with one. Maybe try a different gauge if you have access to one.
tried a different gauge. it read a few psi lower, but i don't trust its readings because it has a design flaw that makes it hard to secure firmly into the spark plug socket.
however, i did stick an extra o-ring on my first gauge and depressurized the fuel line and it read 35 across the board.
and upon further inspection, i took a look at my head gasket, in the very front of the engine there is this place were a few tabs stick out and i am pretty sure that this is an aftermarket head gasket. it is 2 pieces of steel (what i am guessing to be stainless) with fiber inbetween. the stock one is some paper like material isn't it?
what i don't get is, why would you put an aftermarket head gasket on the engine and not put anything else? when i got the engine it was bone stock. unless osaka took the aftermarket stuff off and put stock back on??
i also found this
zerothread?id=112393but he does not specify what size HG he is using.
so i sort of wonder what size HG i have. *goes off to borrow a micrometer*
