12v power outlet removal.
Nissan 350z / Nissan 370z technical discussion forum: Maintenance, performance, installations, modifications, how-to's and troubleshooting.
mike's350z
Car: 2004 350z Touring Package. Factory installed nav/satellite radio.
Does anyone know how to remove the power outlet located between the seats in a 2004 350Z?
The problem I am having is the outlets are not working. One day they did the next? Anyway I checked the fuse and found it was blown. I replaced it and started the car and the outlets still didn't work. I checked the fuse again and it was blown. I replaced it and got the same results once I started the car.
So now I'm removing the outlets to see if they are the problem. Hopefully, I hate to think its the wiring!. Got the one out by the passenger's side, but have no clue as to how to remove the one between the seats. Appreciate any and all insight.
Thanks
Harman850T5
Car: 2003 350z
It's better to do with the cabin warm, so things don't start to break. But just pry on the bottom a little and it should pop loose, and the top just hooks into the back of the panel. If you have a plastic pry tool it may be easier, or a screw driver and a rag.
Return to “350z / 370z Technical”
