IvoryJ30t wrote:an amp rated 200W [email protected] will put out more power than an amp rated 200W RMS@ 14.4volts
vboyq wrote:i am but my question is which one rating should i be looking at realistically speaking in terms of TOTAL power output, when using with the car the 12 volt or the 14.4 volt?
Jookmasta wrote:does this have anything to do with the voltage that the preouts on a deck put out? for instance, i have a p7300 so it puts out 4 volts on the 3 pre outs. but the new p760 puts out 6 volts on its 3 outputs, so then would that deck make it more likely for the amp to see the 14.4 ?
