rbsileighty »
https://forums.nicoclub.com/rbsileighty-u4927.html
Tue Mar 02, 2004 5:35 pm
I would say that is a good read, however keep in mind the following:
Quote »In summary, my suggestion is, until you upgrade the internals of an RB20/25, the standard plenum and TB is perfectly fit for the job. You would be better off spending your money elsewhere. Once you have got to the stage of upgrading the internals, then by all means change the plenum, but make sure you have an ECU that has individual cylinder fuel trim.[/quote]
Quote »Sure there are places for front mounted TB’s and aftermarket plenums, I have used them myself, often. But not on engines with standard internals.[/quote]
Quote »I have tested the flow rates on our Superflow bench of standard RB20/25 inlet manifolds, plenums and TB's and there is no restriction of any substance up to 450 bhp. That's not guess work, it's a FACT.[/quote]
I definitely trust Sydneykid, since he seems to have had a whole lot of experiance with these motors. I have spoken with him several times over emails, and I like his reasoning and thinking.
Fito's car is far from a standard RB25, and is putting out well over 450bhp. This is where my reasoning stems from, in that the plenum is at the least of his concerns. I still agree with what I said before.
This should however help the rest of us who are not putting out that much power in making our modifications. I do appreciate the comments, as they have helped in my decision for my RB20. Looks like I will be keeping with my stock manifold until I can design a better manifold for my 400rwhp goal... or hone the stock one. The 120 deg bend looks like the most ideal route for me.
Quote »So I might just sum up from my perspective; There is only one advantage from moving the TB to the front and that is reduced pipework length. This may lead to improved response, but it does nothing else eg; there is no horsepower advantage up to the limit of the standard internals.
Conversley I won't call them dissadvantages, let's say risks instead; 1. Poor distribution or airlfow leading to lean A/F ratios in the rear cylinders and detonation[/quote]
Again, in Fito's case he has the Microtech which can control each of the cyl's individually, which should allow him (and anyone else in the same case) to overlook the downfalls of a front facing manifold.
