nissanfreak12 »
https://forums.nicoclub.com/nissanfreak12-u177688.html
Mon Nov 28, 2011 8:46 am
If you are going to swap out the engine, I would at very least change the Belt. The tensioner, pulleys and pump you can move to the new engine, which you should do anyway for preventative maintenance. All the seals, I would just hold out until the new engine. Don't go cheap on the parts, if anything fails in this area can be catastrophic.
Here is what I would do, get the kit, the full kit and a second belt. Put one of the belts one the NA engine. When you get the engine for the swap, change everything in the 120k kit. New belts are like cheap insurance, you have no idea when the last time the belt was change on the engine you are going to swap. Unless you have documentation when it was done.
