niznos »
https://forums.nicoclub.com/niznos-u14767.html
Mon May 17, 2004 10:50 pm
The FSM will tell you what to do at certain mileages, but if you have not or do not know if it's all been done at the right mileages before, then it's not really gonna help. I'd say if you don't know what's been done then change all the fluids that haven't been done: coolant, trans. oil, rear diff. oil, and you can even drain the power steering oil (automatic trans. fluid in that thing). Yes, I'd do the oxygen sensor too.
I have heard of (but never actually experienced) some automatic transmissions that fail after a fluid change that has been too long delayed, mostly in domestic models though. The reason, as I was told, was that the transmission was weakened by the filthy old fluid, then the fresh new fluid, with all it's detergents and additives, actually break all the worn parts up and some serious slipping results. Don't know if there's too much truth to this, and not trying to scare you, but just thought I'd say something about it. Anyone with real knowledge should chime in on this one.
