elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Tue Jul 29, 2003 3:25 pm
Rear diff........ The plugs take a 1/2 in drive (square), and you undo the bottom one, and let it drain...... I didnt warm it up first, but that would probably be best...... Let it drain for a good 20 mins, and while its draining take out the top plug (its on the top, drivers side of the diff) and clean it out........ when its done draining put the bottom plug in...... Youll need 2 quarts of 80w90 gear lube...... The board recommended mobil 1 synthetic, but i couldnt find it so i used valvoline synthetic..... I got a pump thing that screws on to the top of the bottle, and that makes things 10000000000xs easier, since there isnt enough room to get the bottle up there..... Youlll pump a quart and a half into the diff, and its full when it starts coming out of the filler hole...... Make sure you clean off both drain plugs really good, especially the top one....... Then tighten both plugs to roughly 40-50ft/lbs......
Plugs- described in 5 words: straight-foreward, but no fun....... The plenum doesnt come off, and taking it off wouldnt make it any easier....... Simply take off all the allens on the black covers, undo the ignitor pack (the box with the 2 plugs on top of the black cover)..... Once you get that off, you will see the individual coils..... I took off all of the coil wires and moved it aside, as it makes things easier...... There are 2 bolts holding on each plug...... undo those and pull the coil out....... Youll need a good extension to get down there to undo the plugs..... undo, and then replace...... Its really easy.......
If you are concerned about plenum cleaning (and not underplenum hoses), just take off the TB and clean it out, and the inside of the plenum.... If you cant do it, have someone reach in there with really skinny arms reach in there and get it as clean as possible........
