Post by bstonedrift » https://forums.nicoclub.com/bstonedrift-u44120.html Tue Aug 15, 2006 6:43 am
Post by naed240sx » https://forums.nicoclub.com/naed240sx-u28231.html Tue Aug 15, 2006 7:21 am
Yes, you could definately fit that setup. Don't expect to be running like 265 and 305 width tires though. You will need to run stretched tires.bstonedrift wrote:would 18x12 -3 rear w/50mm over fender fit on an S13 coupe?and 18x10 -3 front with 30mm overfender?
Post by bstonedrift » https://forums.nicoclub.com/bstonedrift-u44120.html Tue Aug 15, 2006 5:40 pm
Post by naed240sx » https://forums.nicoclub.com/naed240sx-u28231.html Wed Aug 16, 2006 1:22 am
Depends on how much camber you run, how low you are, etc etc.bstonedrift wrote:the tires that I have available are 295/30R18 rear and 265/35R18. so the fronts should be smaller? 235? 245?
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
