noonooJAY wrote:Hey Jonny,
Thanks for the detailed information, that's the best information I've got out of all the forums i frequent. As for the solderless connectors, I'm going to look into that. I already made some connections with the grounds to the door switches via "t taps". I hope those are okay. Man I was using that volt meter totally wrong. I was grounding to a painted surface and you said that's a no go lol. So I ended up taking the sucker back for an exchange thinking it was broken.
Always glad to help a fellow forum member
Yes, for the ground you need bare metal to have a true ground. Most people use the black or chassis, but being that you are inside you could probably find a grounding block somewhere in there or a metal bracket.
T-taps are certainly ok, they just aren't what I use. This is what I use:
http://order.waytekwire.com/pr...0AND/
You crimp the wires, then using a heatgun it melts the solder so you have a crimped and soldered connection. You can't beat that! Also, remember to wrap everything in electrical tape.
Let me know if I can do anything else to help. Regards,Jonny
