12 volt issue
arj491
Car: 2001 Nissan Pathfinder
I have a 2001 Nissan Pathfinder LE
I was attempting to hardwire some LED lights and they were working
then all of a sudden the center and trunk 12 Volts stopped workingbut the front 12volt jack works
I checked the fuses and none of them seem to be broken
any ideas?
Chuck Tribolet
Car: '01 Nissan Pathfinder
'87 Chevy Corvette
'01 Toyota Camry daily driver
'98 Boston Whaler Montauk
The FSM shows a power socket relay, but it also only shows two sockets,not three. Still worth a check.
Qxxx4
Car: 1999.5 Infiniti QX4
2012 Ford Mustang
are you getting any voltage from the rear and center jacks? did you test with a voltmeter? and where did you mount your LED's to
Chuck Tribolet
'87 Chevy Corvette
Upon a closer inspection of the FSM, all three power sockets are there. Thefront one has a separate fuse from the center and back one, and no relay.The center and back share a fuse and relay. The fuse is located in the fusebox under the hood US passenger's side, not the one above your knee. It's #64, third from the right bottom row. 15A. I'll bet you bumped something and blew the fuse. If it's not the fuse it could be the relay. M144, its above thefuses above your knee. There are three relays on the board with the fuses,three more above that. It's the left-had relay in the top row.
arj491
thanks a lot guysim gonna check it out tomorrow and let you know how it goes
Chuck Tribolet
'87 Chevy Corvette
What did you find out?
