Dugi wrote:12.51 sec @ 107 mph.......... but fot into revlimit before I reached finish in 4th.... putting it in 5th would be overkill..... rev is set at 7000 or 7200couldn't remember right.... will raise it a bit and get a bit bigger slicks cause i borrowed and they were a bit small as in low....
Dugi
wow.................................... let me first say for what you are running, thats an almighty time. what was your 60'?
second of all.......... why are you not running more boost? 13psi on that turbo is weak. turn it up to 18 or 19psi at the track and rip it. stock internals handle it without a problem. i am still on stock head gasket and was running 20psi on the dyno.
third...... why is your rev limit only 7k?? it should be stock like 7.5k. rev it as high as you can as you are making a lot power up there.
holy crap, your trap is low for that time. you should be trapping around 115mph on stock cams.
thanks for the times post... this gives me confidence for me when i get out (11s)!
