search the forum before asking things like this. i and many others have explained this plenty of times... i even remember posting this exact information less than a week ago.
checkered member is incorrect.
it does not matter whether you have a 12:1, 8:1 or 100000:1 fmu, your maximum fuel pressure is completely dependent on the ability of your fuel pump to make that pressure. so if you're like pretty much everyone with an fmu setup and you have a walbro 255 lph pump, the fuel pressure cannot just rise without bound as boost increases. it will stop rising as soon as the fuel pump maxes out. the reason why 8 psi is generally the maximum safe boost pressure is because at that point the fuel pump is maxed out and simply will not flow more fuel to compensate for extra air for like 10 psi...
what all of this means is that whether i have an 8:1 or a 12:1 rrfpr at my peak air flow the air fuel ratio will be ~the same because the max pressure of the fuel pump will have been reached... if you increase boost beyond this point you will just start leaning out, no matter what rrfpr you have. i'm not sure what exact max pressure for a walbro pump is, but on an 8 psi setup both an 8:1 and a 12:1 fmu will max out the fuel pump. the only difference is that the 12:1 will do it sooner... at lower boost, which means that you will be running consistently richer on a 12:1 fmu...i think the reason people would use a 12:1 fmu is that the extra fuel (richer condition) will provide a little more safety from detonation, but at these low boost levels using a 8:1 rrfpr is just fine.
oh and i (and many others) have a 12:1 fmu on an 8 psi setup and there have been 0 signs of anything "blowing."
i'm gonna go find that post i made maybe a week ago... i swear it will sound identical to this.
hey look at that... i didn't even have to go beyond the FIRST PAGE!!!!!
zer...age=1
there's the link...pretty much identical information.
