Hey Rick,
I worked with Electromotive to have the trigger wheel machined onto the actual crank pulley. All you have to do is send me the stock pulley, and I'll have Electromotive machine the trigger wheel on it (I'm a dealer for Electromotive).
Some pics:
Regarding the installation, I was able to use existing sensors, except for the MAP and MAT (these had to be added to the vehicle). Stock coolant sensor and TPS work perfectly. The crank trigger wheel and sensor are now bolt-on, so that's not a problem anymore. The stock ignition and distributor is replaced with a direct firing unit, which is basically 2 huge coils directly wired to the spark plugs (waste spark).
I was able to install everything in 5 days, putting about 2~4 hours a day into it.
The software is user friendly, and sets up a base program based on injector size and some other parameters, to get your engine running. You can then tune that program to optimize the engine. Every single parameter is adjustable. You can contact me at
[email protected] if you wish.
