110 RACE GAS....JUS FOR THE SMELL OF IT?
jaco
Car: 95 Nissan S14
ok this question is so stupid i almost wanted to sign-up w a new account...and serched , but can i mix in a couple of gallons of race gas in with 93 on a totally stock tune . (notch top T28 header& full 3" turbo back.and MBC.) ?? dont worry im ready for the... & on this 1...
Hijacker
Car: '92 240sx Convertible
'94 F-150
You don't need race gas. You will not see any benefit of using it over pump gas because a) you're turbo isn't pushing an insanely high boost pressure necessitating race gas and b)your fuel management is stock, so it wouldn't take benefit of higher knock resistance.
Also, if you're running your cat still, race gas could damage it.
jr_ss
Car: 95' S14
You could use 100oct... I used it when I ran 14psi at the track just as a safety margin... But Hijacker is right...
jaco
Car: 95 Nissan S14
no i run a test pipe, but regaurdless il stay away from the hard stuff ...for now . i just wanted my last drifts of the season to smell like candy thats all! thx boys
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
Run like 1 gallon in as an octane booster to help with any detonation that might be there. I run 1-2 gallons of Cam 2 in with the rest of 93 octane.
93bluecoupe
Car: 93 purplish blue coupe s13
the lead in the 110 will kill your o2 sensor. you can use 100 unleaded if you like? pretty expensive just to smell good.
Hijacker
'94 F-150
DrifterProdigy85 wrote:Run like 1 gallon in as an octane booster to help with any detonation that might be there. I run 1-2 gallons of Cam 2 in with the rest of 93 octane.
But you're also not running a stock setup.
jaco
Car: 95 Nissan S14
tru tru tru ... thanks to all who responded, im just gonna stick with my sunoco 93 , has'nt failed me yet .
JdrifterCA
Car: 1992 240sx LE
sorry. not to thread jack. sr20 swap almost done.. well im runing stock boost at 91 oct. would my car knock? is prettty hot in california desert.
jr_ss
Car: 95' S14
No, unless you raise the boost to 1bar...
WizardBlack
Car: 1977 Datsun 280Z w/ RB25DET
100 octane unleaded doesn't smell any better. It's the lead itself that makes it smell good.
Torco makes products that you can use specifically for the "safety margin" for track sessions.
Adictd2b00st
Car: 95 240sx
love the smell of race gas
