I haven't done much in the way of fuel modification, but I remember asking my instructor a similar question a few yeas ago. He told me that if I could get kerosene then that would be perfect octane-wise but basically an unnecessary expense just like using 93 octane on a low compression engine that could make do with 87 octane.reefscape15 wrote:... I always run 93 in my car. Is it safe to fill with 110 and if so, will it cause any worry/damage? ...
Ok, that's good to know. This really will be the only time the car will be on the track. I do drive it hard sometimes and get on the brakes hard if I need to, but nothing more than just having fun and blasting around. Track day will probably be 9 laps this year. I guess if I destroy a cheaper set of rotors in that short of a time, I'll just buy another set. I have looked at stoptech big brake kit, but with the age and mileage of the car, I'd hate to dump that much into it just so I could have piece of mind on the handful of times it will ever be needed. Thanks for the reply!Ilya wrote:It's a good replacement for a daily driven car that isn't on a track, for sure. I drive my car like it's on a track...lol. So I usually only get 20-25k out of my brakes. That's why I buy that kit...at $200, it's affordable to change every 20-25k. If It cost $400 and I only got that much from it, I wouldn't buy it.
You can look into Stoptech, etc...or look at the stuff our vendor TunerzStore.com has for sale.
Good point....I guess without any mods or tune for that type of fuel, it wouldn't create any more power. Interesting thought to see if the mileage would be better, but I think last summer it was $8+/gal? At that price I'd rather not know and just pay $2.70 for premiumEdBwoy wrote:I haven't done much in the way of fuel modification, but I remember asking my instructor a similar question a few yeas ago. He told me that if I could get kerosene then that would be perfect octane-wise but basically an unnecessary expense just like using 93 octane on a low compression engine that could make do with 87 octane.reefscape15 wrote:... I always run 93 in my car. Is it safe to fill with 110 and if so, will it cause any worry/damage? ...
And I know that our v8 engines are sort of high compression, but unless it can breathe better, I see the engine management retarding something at worst. On the positive side, you might get better gas mileage.
How about you wait till you're almost empty then buy a quarter tank of it and just drive around normally to see if you can perceive any differences?
So you're saying I'd get higher MPG and performance from 87 than 93? I thought it was the other way around...93 burns cleaner so to speak thus more power and a cleaner engine overall. Thus better MPG.ArmedAviator wrote:My Stoptech rotors and semi metallic performance pads are great. They rust like any other non-OEM rotors but it doesn't affect the performance.
Regarding 110 octane in a stock-tuned engine:
It is completely safe. It is also very dumb. Higher octane means less heptane. Heptane is what makes the gasoline very flammable, and provides most of the specific energy.
Less specific energy means you will get WORSE gas mileage than a gasoline with a lower octane rating and you will gain no added performance without a tune and higher compression pistons or FI.
Do not waste your money.
Higher MPG? Possibly minutely. Performance? No, due to knock sensor/retarded timing to compensate for the lower octane.Ilya wrote:So you're saying I'd get higher MPG and performance from 87 than 93? I thought it was the other way around...93 burns cleaner so to speak thus more power and a cleaner engine overall. Thus better MPG.ArmedAviator wrote:My Stoptech rotors and semi metallic performance pads are great. They rust like any other non-OEM rotors but it doesn't affect the performance.
That is correct. Basically, using an octane rating that is higher than your engine is designed and tuned for may result in carbon deposits due to cooler burning mixture. Running lower octane rating usually doesn't cause that issue as the greater temperatures and when experiencing engine knock, the carbon is burnt up and knocked out some.Ilya wrote:So...the idea that higher octane = less carbon deposits is a myth?
In Cleveland we have the Giant Eagle grocery store chain who also had their own gas station brand (Get Go). Every $50 spent on groceries you get $0.20 off of every gallon of gas up to 30 gallons. My mom does plenty of shopping and bits gift cards from there when doing projects (Home Depot, etc) which counts towards the $50. She regularly gets free gas and her car doesn't hold that much gas. The rest of those 30 gallons ends up in the 5-gallon containers. When I travel home (a 220 mile drive each way) she lets me fill up with whatever she has left.EdBwoy wrote:Btw, ArmedAviator curious minds would like to know why you guys have jugs full of gas lying around, lawn mowing business?
Shouldn't be a problem if anything the car will run better lol. But can always run 93 and half 110reefscape15 wrote:So the title asks the question....story is, I live very close to Watkins Glen International Raceway. Every year on their opening day they let people bring their cars and pay for a few laps. Yes, they are paced laps (at 55mph), but over the years my friends and I have gotten a pretty good crew to run as a group up there. We hang way back from the cars in front of us, and when it's time to get through the corners and onto the straights, well, it's go time! I hit 125+ last year, and scrubbed countless miles off my tires. Anyways, this year I have a brand new set of Bridgestone Potenza re760sports on there. Ordering Breakmotive front rotors....hopefully I can get springs done by then, but that's still a maybe.
To get to the point. I always run 93 in my car. Is it safe to fill with 110 and if so, will it cause any worry/damage? Engine has 156k on it now, shouldn't go up much by April as I have a winter car. 110 is available as pump gas at the station down the hill from the track. Would it make any difference? I mean, I know the smell would be awesome, but I'd hate to blast around and burn a hole through the top of a piston or something. Thoughts? Any input is greatly appreciated.
