How many miles will you put on the car in the three months? The dealership here uses Mobil 1 conventional oil and mile interval is 3750. You could use a full synthetic like AMSOIL. They have a couple different options: Recently released OE which is designed for what ever the car manufacturer recommends and cheaper than Mobil 1 synthetic. XL series which is designed for 6 months or 10k miles. Signature series which is designed for 1yr or 25k miles. Mileage based on normal driving conditions. You can become a Preferred Customer and buy at wholesale cost.IN.G37 wrote:So stay away from nissan ester oil? If I change my oil every three months is conventional oil ok? Any way to know what oil my 2010 G37 has from the factory?.
around 2000k in three months..RED_DET wrote:How many miles will you put on the car in the three months? The dealership here uses Mobil 1 conventional oil and mile interval is 3750. You could use a full synthetic like AMSOIL. They have a couple different options: Recently released OE which is designed for what ever the car manufacturer recommends and cheaper than Mobil 1 synthetic. XL series which is designed for 6 months or 10k miles. Signature series which is designed for 1yr or 25k miles. Mileage based on normal driving conditions. You can become a Preferred Customer and buy at wholesale cost.IN.G37 wrote:So stay away from nissan ester oil? If I change my oil every three months is conventional oil ok? Any way to know what oil my 2010 G37 has from the factory?.
+1joe603 wrote:I recommend Royal Purple. It's been in all my cars for over a decade!
Eh I think that's a bit short and harsh. Ester is a long debate history.... Long story short after the reflash in mid 2008 none of the 3.7 engines really need it.RED_DET wrote:Stay away from the Ester Oil. The dealership around here is doing away with Ester oil changes. Big Hype that has since failed.
What is "Mobil 1 conventional oil"? Mobil 1 is a "full synthetic" brand, isn't it? Their conventional oils are not badged "Mobil 1" as far as I can tell, if conventional==dinosaur. This is not a troll, I might learn something.RED_DET wrote:How many miles will you put on the car in the three months? The dealership here uses Mobil 1 conventional oil and mile interval is 3750. You could use a full synthetic like AMSOIL. They have a couple different options: Recently released OE which is designed for what ever the car manufacturer recommends and cheaper than Mobil 1 synthetic. XL series which is designed for 6 months or 10k miles. Signature series which is designed for 1yr or 25k miles. Mileage based on normal driving conditions. You can become a Preferred Customer and buy at wholesale cost.IN.G37 wrote:So stay away from nissan ester oil? If I change my oil every three months is conventional oil ok? Any way to know what oil my 2010 G37 has from the factory?.
Unfortunately the courts made "synthetic" meaningless in the US as a label in the case between Mobil and Castrol. It took me a while to suss that out for myself. I think we need to talk about PAO or ester based rather than using the term synthetic when we mean oils that are actually synthesized, and even then we probably need to be stating percentages.tollboothwilley wrote:Very few oils out there are "true synthetics" anymore.
