multi thousand dollar fuel system? very specific maps? i don't think so.toki wrote:11:1 will work N/A on 93, I KNOW 11.5:1 you have to mix higher than 93. 11:1 turbo could maybe work on 93 with multi thousand dollar fuel system, simply because you would have to have very specific maps i'm pretty sure. I don't really think it would be worth it on any level.
andrave wrote:why not get forged pistons? the sohc pistons have ****ty ring lands and aren't going to take any detonation...
the sohc and the dohc piston are identical except for the dish dept in the top. both have the same crappy ring lands. besides with forged you could go with a more moderate compression, like 10 or so.. 11 is just really, on stock pistons, on a street car
use a lower compression ratio? kinda defeats the whole idea doesn't it.
-demetrius
3 points? who's raising their compression 3 points?andrave wrote:So how do you figure that you are gonna be fine if you increase compression by 3 points, thereby increasing the risk of detonation?
i'm not sure i want to talk to any of the rsx-s guys you're refering to seeing as how none of the rsx's bolt on turbo/supercharger kits require a stand alone or professional tuning.Checkered-Member wrote:Lets take the example of the Acura RSX-S with it’s 11.0 compression, people have been turbo charging it since it came out, with 4-6psi
Most of them run just 91 octane (not even 93) oil coolers, upgraded fuel system, stand alone and **professional tuning**
That it…
so demcj want 6psi at 11.0...talk to some RSX-S guys
If you are referring to Greddy they come with e-mange and a custom fuel map, so no tuning needed, stand alone is used with custom turbo kits at least I have seen half a dozen turbo charged RSX-S with stand alones…so I guess stand alone might be an over kill on some occasionsdemcj wrote:i'm not sure i want to talk to any of the rsx-s guys you're refering to seeing as how none of the rsx's bolt on turbo/supercharger kits require a stand alone or professional tuning.
-demetrius
comptech, vortech, and a couple of other companies that make turbo kits for the S2000 all boost around 7-8 psi on straight pump gas. no alcohol. that's the goal here.Red Lightning wrote:With a efficient IC and alcohol injection, I don't see why you can't run 6 psi on 11:1 CR. Comptech made a S/C for the S2000 (11:1 CR).
