10mm wheel spacer, where is a good place to buy?
brodilka
This is getting ridiculous.. i searched through all website here, all i had bookmarked and it seems like no1 carrying 10mm wheel spacers.Only its either 5mm or 15mm, what happened to all in between
crzycav86
Car: 93 Nissan 240SX KAT
I have some 8mm spacers, you want those?
Grant@tirerack
Car: Auto racing (AMLS, Cart,F1,IRL in that order), old show rods, classic monster and bad sci-fi movies,
If you check with H&R direct at 888-827-8881 they can hook you up with a local distributor who can fit you with some 10 mm spacers. This is something you would want to have a shop do locally where they have access to the wheels and the car to make sure it's done safely.
Ace 2.0
Car: z32 2+2,1987 CRX si
what are the pros and cons of spacers?
cheez80
Car: percussion =D
Ace 2.0 wrote:what are the pros and cons of spacers?
pro: allows wider track; allows you to fit a wheel that otherwise won't clear your brake caliper/coilover combination; allows the wheel to become more flush with the fender
con: weaker than stock hubcentric mounting; you need to get longer wheel studs if you're not using the kind that has its own thread; sometimes inferior workmanship from unknown brands
anyway, i'm running a small 1/4" pdm spacer right now. as you can see, it's probably best and most secure to get a wheel that has the correct offset from the factory.
be sure to get hubcentric rings for best results!
Ace 2.0
thanx for the info.
Anand
Car: 95 Nissan 240SX
I have some with longer wheel studs for sale if you are interested...
check the for sale forum
Ace 2.0
sorry but i need to pay traffic court costs.
