10mm spacers
06M4.5
Car: 2006 M45
Who here is running 10mm spacers on stock studs? :gotme
I know 5 or 8mm isn't a problem. 2mm extra is not much at all
10mm spacer with studs built-in are hard to find and those that do have them want big bucks.
mexillis
Car: M45s
10mm is fine, some people even run 15 without extra studs. Are you trying to make the frons more aggressive?
06M4.5
Car: 2006 M45
Thanks Mex
I like the tuck look and at the same time be safe. I got the front wheels milled just to make sure I don't damage my fender vents. That 275/30 is big even more so when you turn.
I now have 20x10.5 (285/30) and the rear was made so a 20x11 wheel would fit. I got the car aligned and gave the rear some camber just for looks. Now I have more room and would like to use a 10mm spacer but not willing to pay over $100 for built-in studs when a 15 or 20mm with built-in studs go for around $75.
Just wanted to ask that a 10mm spacer was safe to use on stock studs on our M's.
WARNING: Don't come to my area with 20x10 with 225/35 and your wheels are poking, your not going to be happy. :nono:
svard75
Car: 06 M35x
Yikes 10mm for me would not work. You need to have the bolt at least to the end of its threads for safety. Unless you have freakishly long studs don't do 10mm spacer.
White-Rush
Car: 06 M35S - Sold
11 M37S - Ran hard and sold
16 Q70S
hmm, good information here. I'm on the hunt for spacers too.
mexillis
Car: M45s
I guess the rim would play a role too, depending on how fat the wheel is to the hub it could work or might not.
06M4.5
Car: 2006 M45
so I guess 8mm just to be safe
DoN_BLaZe34
Car: 2007 M45 Sport - Sold
2006 FX45 - Traded
2014 Q70S 5.6 - Sold
2017 Q70L 5.6 - Current
I personally wouldn't go above an 8mm without studs
06M4.5
Car: 2006 M45
DoN_BLaZe34 wrote:I personally wouldn't go above an 8mm without studs
I just tried a 5mm spacer & I have 9.5 turn on the lug nut.
Most are saying you need a min. of at least 6 turns, anything less would be dangerous.
How many turns does a 5mm take away?
DoN_BLaZe34
2006 FX45 - Traded
I don't know offhand. If you have access to another 5mm add it then recount how many turns you get from it.
Or
Count how many turns you have when you take the spacer off...the difference would tell you many turns you lost.
06M4.5
Car: 2006 M45
DoN_BLaZe34 wrote:I don't know offhand. If you have access to another 5mm add it then recount how many turns you get from it.
Or
I"ll give that a shot over the weekend :dblthumb:
06M4.5
Car: 2006 M45
I just found out that the diff from 8mm to 10mm is only 1/16"
stm37s
Car: '12 Chrysler 300 SRT8
'11 Infiniti M37 S
'06 Range Rover HSE (Wife's)
'12 Chevy Camaro LS (Wife's)
'95 Chevy Impala SS (sold)
'04 Chevy Impala SS (sold)
'12 Hyundai Veloster (Daughters)
this is gonna be very interesting
svard75
Car: 06 M35x
Some weekend reading material on wheel separation.
http://www.meaforensic.com/wheel-separa ... -forensic/
"Ideally, you want the same engagement onto the thread as the diameter of the stud.
IE. M12 stud - you want about 12mm of engagement.
M12 x 1.5 pitch stud (typical for Toyota) equals 8 turns of the nut (12/1.5 =8).
5.5 turns of the nut times 1.5mm pitch = 8.25mm of engagement which is not ideal."
I think this anonymous quote makes sense to me for safety reasons. Many others are saying various other amounts but at the end of the day it's torque that holds the nut onto the stud. If you can apply the min necessary torque after the spacer without stripping the stud or nuts threads in the process it might be sufficient but I would still stick on the side of caution and look for full engagement.
I don't want to see any M's in the ditch or anyone here getting hurt.
06M4.5
Car: 2006 M45
I haven't had to much time to search for a 10mm hub-centric spacer that comes with the longer studs.
The little I did I already know to stay away from the ones on ebay selling for $66-$67, the spacer isn't 1pcs with the hub-centric part (it's 2 parts) and the studs are cheap. It looks nothing like the pic used on ebay.
The only one I saw was the one made by Eibach but the price is over $100 for just 10mm :frown:
I'll have to do a better search as soon as I get a chance.
