100k mileage Maintenance help..
s14-d
hi, i am putting together a list of what i need to do for the 100k Maintenance. so far i've came up with the following.. (* = have changed already when i bought the car at 70k)-transmission fluid*(redline transmission fluid)-break fluid-diff fluid*(redline diff fluid)-plugs*(laser platimum)-plug wireset-disturbitor cap and rotor-coolant-clutch fluid-what else?..... any thots guys?
Lt.Mike
Car: 89 240sx
There is also-Change fuel filter (upgrade to late model turbo 300zx. Adds throttle response, and it fits)-Seafoam your engine (in gas tank, crank case, and brake booster. May open up leaks when put in crank. Should be done before fuel filter change)-re-adjust throttle cable to have more tension (change throttle cable, or use rubber washers to take up slack in throttle fork end)-don't forget oil change-refill ambient signal light fluid (j/k)
That is what I did w/ my car.
