$1000 Of suspension madness!
Tai Mai Shu
Well summers here meaning I work my *** off for my car! So what to buy...I deicded to hold back on the turbo and other stuffs for now, thats going to be winter/spring upgrade but for now I wanna make my car handle better than it already does. 1990 Nissan 240sxSR20DETParts aquiredTein Sport SpringsKYB AGX'sThats it! I need other parts, and dont go off saying oh you should get coilovers...Im fine with this set up, its stable and I can throw my car into the coners. So what else should I get? I was thinking sway bars, Deffiantly need a LSD, that takes away 300 of the thousand, unless you have better spent 300 bucks. One wheel burnouts suck! Im mostly into drift, but dont be suprised to see me at the autocross.
Thanks for your .02yen.
BadMojo
Car: 2007 Mazdaspeed 3
Unless you have some good connections, I think an LSD (an OE VLSD) will go for closer to $700-800 than $300. Can anyone else confirm?
Other than the LSD, you could go for some new bushings. Whiteline are popular but expensive. Suspension Techniques might have an S13 set of bushings. That would be a good, cheap upgrade.
Rockenreno
Car: 1997 BMW M3
You can grab a vLSD for around $250, no problem. I believe its the R200 vLSD that came off of Infiniti J30's and a couple other Nissan cars... If you want a real LSD, like a Kaaz 2 way, that'll run you around $1000...
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
you can get direct bolt on silvia LSD's for 300-450 from difforent sources. The nismo LSD kit looks pretty bangin' too :ylsuper
silviaNE
Car: cars what else?
sway bars, adjustable tie rods with spherical bearings, nismo suspension bushings, strut bar up front, roll cage. I have seen r200 diffs on e-bay go for 300 or under all the time on e-bay.
Exar-Kun
Car: 2005 350Z
VLSD talk to adam at after-dark to get one, 300 bucks...Get a set of sway bars next. that will run 500 for both, then just check out things like pillow ball mounts(HKS and TEIN pillows work with stcok/KYB hardware) and such..-chet
lok
Your car sounds exactly like mine
90 240sx fbj30 vlsd - 150 w/ axelsKYB AGX - TEIN S TechSR20DET ordered from Adam
and I am always looking at parking lots for spots to practice my driving.
MainEvent212
Car: 95 Nissan 240SX SE w/ SR20DET+goodies
wow, a j30 vlse w/ axles is only 150 bucks?
hook me up w/ one of those! lol, i need one
