MattB wrote:you can go longer between oil changes (some say up to 10,000 miles but that's a bad idea).
Personally I change my vehicles every 5k w/ full syn.
But the quoted statement above is simply not true. I knew a guy awhile back who used to get his oil tested. He got up to ~14,000 miles on conventional oil before its viscosity (sp?) and other properties started significantly declining. It is important to note that if you plan on doing this you should change your oil filter at least every 5k (if not more) and have your oil tested regularly.
As i said, i change mine more regularly b/c I feel like its too much hassle and oil isn't that expensive, so I may as well just change it. But a good oil can last longer than 5k, depending on driving habits, conditions, and enviroment.
