Yup, a normal labor rate least for the area I'm in is $84 a hour. So if that gives you a idea....nghtrain88 wrote:for parts and labor, it sounds about the norm
evildky wrote:these cars are expensive to repair and maintain
The plenum bypass is not something that can be easily added when doing the 120k service. They don't even pull the plenum, and doing so is almost completely separate labor.jdubs wrote:1K is very reasonable for this maintenance
Just make sure they have done it before and have experience.
Have them bypass the plenum coolant lines while they are in there, you will significantly improve the reliability.
You shouldn't have to touch it for another 8 years at least
Very true, additionally the parts list that the original poster referenced is a 60K maintenance, not a 120K. The 120K requires both idler pulleys and studs to be replaced and increases the cost by approximately $200.evan_aggie wrote:
good infoSilverTwin(OH) wrote:
exceptional for a 120K if they are indeed replacing the idler pulleys and studs. The studs are a mandatory replacement as part of a 120K.
