100 octane gas
Including HI and CA
ale89se
Car: s13 silvia
does anyone know where there is a gas station that has this octane at a pump in the so cal area? thanks
b1ks14
Car: 1998 240sx
think there are a couple in huntington beach. On beach and warner if ur familar.
ale89se
Car: s13 silvia
thanx. anybody know of any other?
CybeRise
Car: S14 Silvia
there is one in Pasadena where the 110 ends
ale89se
Car: s13 silvia
that's the one i'm looking for. thanks
Twinchy
Car: Peg leggin 240sx
yeah at the end of the 110 freeway in pasadenaits a 76 gas station
ale89se
Car: s13 silvia
thank you both.
CybeRise
Car: S14 Silvia
wtf don't thank him, I pointed it out first! lol
Anyways, did you end up going? How much is it per gallon right now?
ale89se
Car: s13 silvia
just came back from there right now and it was $6 a gallon. and 2.99 for premium. so i got $15 of the great and the rest of the good.
CybeRise
Car: S14 Silvia
did it make a difference? And would it make a difference on a KA engine
ale89se
Car: s13 silvia
i'm actually only running a ka but it is tuend to be reeeeeeeallly rich, so it back fires alot, but with this gas it's almost non existant! so i like it! it feels almost the same, maybe a little faster.
sp33dg33k
Car: 1997 240sx SE
My car is due for smog, would it help if I put 100 octane to eliminate the knocking? Check engine light is on and I have reset it one time and it's back again.
BTW, I am planning to rebuild my engine soon so if you have any info (i.e. parts, good rebuilder, etc.), let me know?thanks.
CybeRise
Car: S14 Silvia
what year is your car?
Red coupe
Car: 92 Nissan 240sx Coupe
if its leaded gass it might mess up you emissions test...
What do you have done to your KA that it requires 100 octain gas? I think most people just run theirs with 89...
sp33dg33k
Car: 1997 240sx SE
it's 1997 240sx. I just want to minized the engine vibration. I think I need to replace the engine mounts. The engine doesn't shake when the mixture is rich. when the engine just started up early in the morning (over 1,000rpm), the engine doesn't shake.
sp33dg33k
Car: 1997 240sx SE
Red coupe wrote:if its leaded gass it might mess up you emissions test...
The engine is stock. I was just thinking that maybe 92+ octane can provide a clean and good combustion. In addition, instead of buying an octace booster, just use the 92+ octane.
thanks all.
Red coupe
Higher octain gas is just gonna be more resistant to burning...its not some magic power forumula, Dont raise the octain to fix your car, fix your car then raise the octain
Return to “California Region”
