bgilly wrote:Higher octane won't do anything for you unless you need it to reduce detonation, because that's all its good for. If you can get away with running 87 octane, you should. You'll make more power because it burns sooner. Running too high an octane will just reduce power for the same reason, it burns later in the combustion cycle. The only perk to high octane at most gas stations like Chevron is that they add more cleansing agents.
As I understand the concept, higher octane allows for greater compression and lower burn temperatures which allows engine timing to be optimized. The engine runs cooler especially under high load and high rev conditions. This is a good thing. Also, especially for the J, is increased torque in the low rpms.
The two oil companies shown developing "Premium Plus" in the article were BP and Shell.
The representitives said that the fuel also allowed for better cold (not up to operating temp) engine performance. This struck me as odd but then I remembered something my brother told me. He lived in Germany for a couple of years. He told me that there is a strict law against idling IC engines. One cold morning, he started his car and then started scrapping the frost off the windshield. An old guy was walking by and yelled at him to shut the car off! And drivethrus? faaggedaboudit! Get in and go, I guess.
