Darius wrote:cjmartz2k- If he is running in closed loop and the fuel pump is not keeping up for whatever reason, will the PFC automatically increase injector duty to compensate?
If he's running the stock map, there's no way there would be a rich spot on it that would cause the injectors to max out at only 8-10 lbs of boost on the stock turbo. Exhaust leak upstream of the O2 sensors?
silvia- Do you have the PFC boost control kit or a separate boost controller?
For the coolant temp sensor, what does it show for the coolant temp on the hand controller? Should be like 80-85C.
Darius you are right that the PFC will compensate under closed loop, i.e cruising. However once he goes WOT, it will switch into open loop and run solely based on the map. So it shouldn't have anything to do with it.
Yea check the sensors for anything out of the ordinary in terms of temps and post up what the MAF volts (and wideband reading) when you are getting the 100% IDC.
