100,000 miles maintenance
CapeCodChips
Car: '14 Nissan Rogue SV Gun Metal Grey
2014 Rogue SV
What services do the pros (you guys) suggest at 100,000 miles? I just passed 110,000.
So far:
CVT went at 64,000 miles, also replaced CVT fluid at 95,000 miles. (I'll do that about every 50,000 miles)
Pads and rotors replaced at 105,000.
Blower motor and misc recalls
Oil changed every 5,000 miles with 0W20. Air and cabin filters every 30,000
Only thing I notice is (slight) ruff idle at stop lights
What should I be doing?
Plugs and wires
Coolant
Bleed brake fluid (never done that on any vehicle I've owned)
Flush power steering fluid
Thanks!
ImStricken06
Car: 2008 Nissan Rogue (sold)
2013 Hyundai Santa Fe
2016 Kia Sorento
oil change
engine air filter
cabin filter
plugs (leave the coil packs alone until they go)
coolant
brake fluid
tire psi check
brake pad clean
clean & lube caliper slide pins
inspect caliper boots/seals
inspect all control arms/ball joints/sway bar links
change fan belt
inspect cv axle boots
transfercase fluid drain
differential fluid drain
a/c freon (r134a) level/pressure check
clean & inspect pcv valve - diy video below
(this car doenst have power steering fluid)
wipe & lube the door seals
inspect all light bulbs
[youtube]http://www.youtube.com/watch?v=pQJjqRQYDmc[/youtube]
darylzero
I would add giving the MAF a quick clean. May help with your rough idle. Use the CRC fluid make for cleaning MAF's.
Return to “Rogue Forum”
