mach5camaross »
https://forums.nicoclub.com/mach5camaross-u31339.html
Thu Feb 14, 2008 8:36 pm
What I would do:
Build motor, Custom Intake manifold, Build head with cams, Brakes to stop, Custom turbo manifold with gt35r or compairable turbo, q45 3.63 rear end, 26x10 slicks with drag rims, CalumtuneRT, clutchmasters stage-5 clutch, cryo treated transmission and 1 piece drive shaft. If you do work youself you should stay under 15k. Or you can do a auto setup but cost would be more. I did not really mention the basic turbo parts that everyone needs.
I have over 15k into my car, but when its all setup right I should run low 11s on pump gas, but swap my coilovers in the back and go place in the top 10 at auto-x all the time, and can murder up the road course as I improve my driver skill.
