zengshengliu »
https://forums.nicoclub.com/zengshengliu-u122532.html
Sun Feb 10, 2019 7:41 pm
I encounter a similar issue with my 08 Rogue SL today. I was driving from Richmond VA to Philadelphia PA. There is no traffic the entire way so I was traveling at around 70 mph. I stopped at a service station, stop the car (no issue so far). When I come back to the car and try to start it, it started, then the RPM slowly drop and stall. I tried restarting a couple times but still have the same issue. I then try holding the gas and crank, and it started with RPM holding at 5-6k for a few seconds. I then let the gas go and it seems to be back to normal again. I did make a few stops later down the drive and the issue disappear.
This feels like the computer is "stuck" on highway driving mode and when starting the engine, it "thinks" it has enough air from the moving vehicle but in fact it doesn't, and stall out the engine.
I did use Shell as my only brand of gas to use (other than emergency situation which rarely happen) so I don't think its dirty gas, and it didn't happen in the later restart which is weird if it is hardware issue.
