LEMHEAD16 wrote:Okay, I hav esearched for my answers and I think my set up will work okay, but I wanted to run it by some of you more experienced guys.
Here's what I am planing
T3 super sixtyInternal WG set at 10 PSI370CC injectors from CA18Walbro Fuel PumpEclipse intercooler (Side Mount)SAFCEclipse BOVCustom 2 inch IC Piping2.5 Inch DP and Exhaust
I was planning on runnning 6-7 psi but the turbo I bought has a 10 psi wastegate so I figured what the heck! If your gonna get wet you might as well go swimming! right!
Please let me know if you think I am lacking somthing in my set up. I have most of the parts already except FP and SAFC.
Thanks for you input
I have a very similar setup; t3 super 60, JWT ECU, walbro 255lph 370 cc injectors (cleaned/flow-tested/blueprinted), soon to be FMIC w/ 2.5" piping, alc injection, 2.5" mandrel bent piping turbo back, no cat. I think with a T3 super 60, which can't flow THAT much air, 10 psi is fine for those injectors; it seems to run well on mine...except for the crappy boost drop off due to god knows what (possibly the mbc). With a bigger turbo that can flow more, you could very well max out the injectors or MAF at the same boost.
However, I'm intrigued that you said yours has an internal 10 psi wastegate--which is exactly what I'm looking to run. My internal wastegate is like 6-7 psi....and that's what you're looking to run....I'm thinking maybe we could trade? Drop me an e-mail,
[email protected]
However, I have no idea what's involved in changing them? Is it just swapping out the wastegate diaphragm/rod that connects to the turbo? Could someone answer this question?
