10 pounds of boost
silva180sx1515
just wondering if anyone else has had the problem of not being able to make 7 pounds of boost. the lowest i can make is 10 for some reason.
180fan
Car: 89 fastback
do you have an aftermarket wastegate actuator? if it's stock, might be a bad wastegate actuator or it's just stuck. that should be at 7...
Spins
Car: spending too much money on my cars.
Mine stock with 3inch dp & exh. would max out at 8psi.
Def
Car: Cars, Engineering Stuffs
Mine did 8.5 psi GReddy turbo outlet, DP, TP and exhaust. Put the silencer in and it dropped to 7.5 psi.
creophus
Car: 240SX SE & 200SX
silva180sx1515 wrote:just wondering if anyone else has had the problem of not being able to make 7 pounds of boost. the lowest i can make is 10 for some reason.
Yeah, but I wouldn't call that a problem! I think it's because I have an S13 throttle body which is a bit bigger than the S14. Also, I have the 3" dp.
got2b240
Car: 91' RPS13 = GT28R, 525cc, Z32 Mafs & SAFC, Blitz EXST & FMIC, Silvia VLSD
yeah i have a 3 incher dp, and my autometer reads a max of 9psi. I think its because of the free flow
mynismo
yep
the freer flow you have the more boost you're engine will automatically make.
3" outlet, 3" downpipe, 3.7" exhaust, 3" test pipe, tubular manifold, greddy intake, and its pushing .65 bar with no boost controller
got2b240
haha sweet
