My valve cover has 10 bolts (4 in the front). The 12 bolt version has a 5th bolt in the front row.
After removing my 10 bolt OEM valve cover, I noticed that there are actually 12 bolt holes in the engine block. Strange that the OEM valve cover only used 10 of the 12 holes.
I bought a Dorman valve cover with 12 bolt holes. So should I:
1. Just use my 10 bolts and use the 10 holes as per OEM. Ignore the 2 extra holes.
2. Find another 2 bolts and use all 12 bolt holes?
Does it even matter as long as I tightened the bolts as per service manual sequence and torque?
