Hello everyone,
I've had my 2010 altima for a while now and I just noticed that there's no light at all on the gear shifter console where you have the P D N 1 2 3. I figured the bulb is burnt out so I purchased a replacement. So I looked up instructions on how to replace the bulb and I was able to pull everything apart and even switched out bulb w/o any problems. However, unless i'm missing something, the harness that would power the bulb is not connected to anything. I looked in there inside and out to try to figure out where it would connect but I couldnt find it. I'm hoping other owners can help. First, does that light work on your card (for the console gear selector) and if so, by any chance if you can tell where the harness connects to anything.
Thanks in advance
