07V84Z wrote:As for the turning off the car saving gas, why not? I remember when I used to do that and my friends used to throw the old myth "It takes more gas to start the car than it would to run it..." at me. Maybe with older, carburated cars, but that isn't true at all anymore.
I don't shut off my Rambler at lights, because I'm afraid that POS Holley carb under the hood will flood and I won't be able to restart. Though the amount of fuel consumption at idle is probably way greater on the carb vs. my two fuel-injected cars. Lucky for me I'm planning on injecting the Rambler one of these days.
(snip)Quote »downshift a lot and everything, and the next week I shifted below 4k RPM and didn't downshift much, if at all, and I tell ya...the difference is amazing. That, in essence, is a partial solution to gas prices. If people everywhere would just drive a little slower, drive at a lower RPM (Ie a higher gear if possible) and just relax a little, we'd use less gas.[/quote]It's going to be an uncomfortable conversation I have with my best friend when I point out to him the reason he's only getting 22 MPG is because of how aggressively he drives. He will cruise down a city street at 3500 rpm, with gears to spare, and not shift. And he rides peoples' tails (and his brakes) like no tomorrow. His justification? "If I'm not sitting there, someone will just cut on in". So? let them cut. let the potential accident be THEIR problem, just keep sitting back far enough to be out of trouble.
Quote »Anyone else think it's just about time for the government to step in here? don't you think that the gas companies could go a little while without charging so much? If they would cut their national profit by even 25% it would save the consumer hundreds of dollars a year. I don't know, I'm no expert, or analyst or anything. That's just what I think about it.[/quote]The only "intervention" the government should be allowed to have in the case of fuel prices is the right to suspend or eliminate gas taxes. In my state and county, there's something ridiculous like 58 cents of taxes on each gallon of gas. If these were suspended, I'd actually be paying just under $3/gal.
If you start having the government regulate industry more and more, you move more towards the socialist side of economics and society. Yes, there need to be SOME controls over industry so they don't wildly rape everyone and everything, but they should NOT be micromanaged by Uncle Sam.
Also, when you look at the grand scheme of things, the actual PROFITS of the oil companies are just a few pennies a gallon. Having them reduce this by 25% will do next to nothing for Joe Blow in the short run, but the effects that trickle down from the stock market would be absolutely brutal to what is left of our economy.
