Blood1 wrote:Hi Doc. I have the following:
Kenwood KDC-X792UInfinity Kappas 6.5" & 6x9's Front & Rear10" Kicker L7 wired @ 1ohmKicker 350.4 (90W @ 2ohms)HiFonics 1210D (1200W @ 1 Ohm)
The box is a sealed box. So instead of getting a bigger 12" ported box, you suggest just get a different box that is ported for the 10" Square L7.
This is the sub in the box:http://www.sonicelectronix.com....html
Oh yeah I thought about this more. I do like my mids, highs crystal clear in terms of SQ, but I realized now I like my bass, low boomy and sloppy as you would say.
It just fills the music more. Like when I was listening to say Metallica and when the bass drum hits, I felt nothing from the sub. It was all mid/highs. I remember with my old system with the band pass, when the bass drum hit, you got a quick boom feeling around you but it was short/quick.
Modified by Blood1 at 3:46 PM 7/23/2009
ok, as long as you like your highs and mids, that's fine.... from a sealed box, you should be getting pretty good bass response from the L7... if it sounds like there is a gap in your music, then this may be a tuning issue...
ideally, your sub should reproduce sound from 35HZ -- 150HZ pretty accurately... however, I just checked the solobaric website, and the 10" L7 has a frequency response from 24HZ to 100Hz, and you limited that even further to 35-->100Hz.
Question, where do you have your highpass crossover set on your 4 channel amp? SOme folks set that high so as to limit the amount of bass being reproduced by the 6.5. In a passive crossover system, if too much power is applied at high volumes, the midbass can bottom out, causing that nasty "blaahh" sound. If indeed your high pass is set to 120 or 125Hz, then you may hear what sounds like dead spots in your music.
however, your case may be as simple as your sub box. IMO, kicker L7's, Rockford T2's, and JL audio W7's should NOT be in sealed boxes. It limits the potential of the sub. And as Imentioned, if you're going for SQ, then you probably shouldn't have chosen the L7.
In any case, is there any way you could put your sub in a sealed box, see if that fixes things regarding the way you want it to sound. In the end, you may jus tend up going with the 12" L7 in a ported box... sound to me like that's the sound you're looking for...
oh, one last thing, that 10"L7 only wants about 600 watts RMS.. you have it wired down to 1ohm, so that amp is giving ti 1200watts RMS.. that's WAAAYYY too much power, and you will eventually blow the sub overpowering it like that!
At least the 12" L7 can take 750 watts RMS.. but in your current situation, I give you 6 months tops if you listen to your music at high volumes!
