WDRacing wrote:I suppose Eric or I will have to be the guinea pig as usual...lol.
Yessir. Already dabbling in it as we speak!
Ok, imagine your gas grill and the regulator that plugs onto the tank. 99.9% of homeowner grill regulators are preset for 1 psi of pressure or less. And they aren't variable. The knob on the tank wouldn't suffice for such a small change especially at 1 psi of flow.
That said, me and my buddy with a '95 F-350 with the 7.3L PowerStroke have been playing with the propane. Particularly because propane has been proven time and time again with the diesels. Being new to propane injection, we have been playing around with his truck.
Ace Hardware, (or maybe other stores), sell a 20lb propane cylinder regulator that allows a max of 10psi of flow, and the regulator is adjustable with a knob. It's particularly used for large shop heaters, or furnace's that require a larger amount of flow/pressure to operate. Needless to say, we acquired this device..
Ran a tube through the firewall to the filter tube just in front of the turbo. Meanwhile the 20LB cylinder is chilling in the backseat just behind the center console. (it's not illegal in FL to ride with 20LB or less compressed cylinders inside your vehicle, thank god)
Anyways, with this rig setup at cruising speed, the diesel makes 4-6psi of boost. The propane injection causes a crap ton lower EGT's too. Wide open throttle there is a big difference. It helps his truck is a 6 speed so we can feel the little differences in power. It's not a speed demon, but it pulls nasty hard.
Ok. Now with all that said, the ideal setup would to get a solenoid to put inline and activate it with a hobbs/pressure switch. This is something we don't have at this point, and because of this, we will not be putting a 20LB cylinder in my car.. lol What sucks, is that a nitrous solenoid will not flow enough I don't think. I have some air brake solenoids off the garbage trucks that I work on, so that might be an option soon.
Sorry for the speech. If anyone wants pictures of details, I'll snap some. I will definitely log the project if it's crossed over to the KA.
