Dustin240 wrote:What, I'm using a 10:1 FMU and open BOV with no problem.U just have to move your mafs by the TB and place the bov before that. That way your not venting meter'd air. And make sure the FMU's source is after the TB.
My BOV is on the hot side in the wheel well and it's F***'n loud. People go runing for cover
His setup is called a blow through. Its one of two ways to install your MAF. Obviously his is after the turbo, hence the blow through, most people put it anywhere on the coldpipe that runs between the IC and the throttle body. You'll just need to extend the wiring harness for the MAF to reach the other side of the car.
Pull through is what MAF controlled cars use from the factory, I can't think of any that use a blow through. Both methods have worked well and both have had issues. But I've seen it done right and it worked very well, even with a open BOV.
Pull through, or Draw through
Blow through
Just a couple of quick pics, I know its a V8, but same concept.
