#1 will NOT fire! no matter how hard i try!!!@#$%
skribblah
rb25 /s13 / mckenny wire job
removed coils and CAS, spun cas and watched each one spark, except #1.
replaced #1 coil pack with #2 coil pack (which worked for sure) [no spark]
pluged #1 plug into #2 and vice versa, #1 sparked and #2 did not.
any ideas?
Fearsome_tea
Sounds like a wire not connected or not making a conection. Got a mutimeter?
Carl H
s1 or s2 motor?
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
check for the basics. Check the wiring loom at #1 for 12vdc ground and ecu pulse signal. while cranking. That will tell you if it's the igniter or ecu
skribblah
s1
so the if the ignitor were bad, it would cause the cyl. to not spark?
Carl H
bingo, could be a fried ignitor.
skribblah
thanks for the tip guys. ill swap my ignitor with my friends (rb20) and see if it works. ill post the results.
stay tuned.
Reaper
Car: 96 & 91 240sx
please get back to us on this ASAP. I'm having the EXACT same problem on my s1 rb25.
Booztd 3
Car: 1990 Nissan 300ZX TT
This shouldnt be that hard of an issue to track down.
Really there arent that many components in the electrical system that deal with firing the coil..........
You've got the CAS, Igniter, ECU, Coil Pack, IGN Relay, Spark Plug, and the wiring itself that all have to do with the spark.
Since you say that you've replaced the #1 coil pack with a known good one and you still arent getting spark, that means you're not getting a signal to the coil pack. Now you need to work backwards from the coil pack to find where you're loosing the signal. My guess it would be on a bad ignitor, but like I said you're going to have to work backwards to find the real cause.
