1 Vacuum Line?
bce240
Car: 1992 Nissan 240sx Hatchback
I saw this post on the KA-T forums and this guy was only running 1 vacuum line to the fuel pressure regulator. He took off all the emissions stuff too. Is it safe to do this? Does the engine still run right?
neverlift
search biotch no he ha dto have a tee or another one hooked to his brake booster.
wh you want to kill trees?
matt4pl
Car: cars, anything fast, graphic design, lots of stuff
i have one running to the FPR, another to brake booster, and one for the MS, which is t'ed off the fpr line.
bce240
what is MS?
matt4pl
megasquirt, standalone ecu
bce240
i know this sounds stupid, but i dont have that right? and do i need the SCV?
matt4pl
no... what is an scv?
bce240
swirl control valve i think........saw it on ka-t.org........i might as well keep it i guess
matt4pl
those are also called secondary butterflies. they are in the intake runners close to the ports, and are vacuum controlled. some people remove em, and i see it as a restriction in the intake. only s13's had them.
bce240
so would you remove them?
matt4pl
probobaly... search, see why people remove em, and waht involved, then decide for yourself
neverlift
I'll hook you up we have a write up for it on nico just search it.
I took mine out as I'm one of the a$$ that thinks sohc ka like to rev over 5k. they are kinda like a vtec please excuse my lack of a better word, they help control "swirl" to create greater low end POWA,but say f off to top end hp. My personal biew is that the ka makes plenty of ft*lbs down low with a nice flat power band without them so why not gain a bit up top. A nice way to compliment that is header/exhaust. as ka is restrictive more so on the ext side....... its kinda a debate atm, if you plan to eprom tune you may consider leaving them and tune around them,IIRC someone on that forum was doing this, dont remember anything else tho...
btw I was messing with you about the whole tree killing thing
bce240
thanks for all the help guys. i think i got it the way i want it.
