1 to 1.5 bar on stock turbo?
chaos2000
Car: 89 240sx HB (s14 sr20det)
90 240sx Coupe (nothing,yet)
ok i just wanted to know if this is normal, i recently swaped a s14 sr20 into my 90 hatch. i have walbro fuel pump 3in turbo back apexi exhaust hks ssqv bov no name front mount and the motor came with upgraded cams i just dont know what kind. but my question is its pushing 1 to 1.5 bar it will hold boost all the way to redline but i dont want to blow my motor due to over boost. so is this normal?
mRodiek
Car: Stock Hatch
They say not to push the stock turbo past 13psi [just under 1bar]. Its your risk though
chaos2000
im not trying to risk it thats why i was asking so should i just baby it until i get a boost controller?
White Comet
Car: fc, s13 and mazda6, Sierra
1 bar is safe on a properly running motor but any more is pushing it
Wretched
Car: 93' Hatch
Sounds like a wastegate issue. where do you have your boost reference tapped into? Any weird bends in the wastegate linkage?
Btw, a boost controller won't fix a faulty wastegate.
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
Wretched wrote:Btw, a boost controller won't fix a faulty wastegate.
+1 A boost controller can only bring the boost up, not down.
Justin35ll
Car: s13 coupe sr20det
you'll probably blow the turbo before the engine if it was overboosting anyway. That is if it doesn't completely lean out due to the extra air.
i run my t25 at about 12psi some days with no tune and no a/f controller
chaos2000
i followed the vac diagram that i found here on nico and no theres no weird bends. but i read a thread earlier about how your supposed to be able to move the wastegate arm by hand and i cant move mine at all. plus i dont think ill run lean any time soon my car is running super rich right now.
dc1984
Car: 93 240sx/98 180sx blacktop sr20det :RIP/ 93 jeep grand cherokee
is it 1 or 1.5 bar because that is also equal to 14.7 - 22.05 psi (assuming 14.7 psi= 1 bar which im pretty sure does). either way a bit a psi for a stock turbo, not sure about the s14 turbo but the s23 runs safely around 12-13 psi, stock actuator is like 7-8 psi ther so u gotta ask urself what is goin on with ur actuator to be allowing so much boost. probly went to crap and needs to be replaced.
do u have a boost only source going straight to ur actuator with no tees?
White Comet
iirc 1 bar is 14.3 psi but i'm too lazy to google it
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
don't know about the wastegate, as I've never tried to move mine. How are you measuring your boost levels? You could have a faulty gauge or sensor and it's just reading higher than what you're really boosting.
dc1984
looked it up, 14.7
