SilverTwin »
https://forums.nicoclub.com/silvertwin-u47466.html
Mon Dec 04, 2006 5:58 pm
NA or TT? Only difference will be where the drive shaft mounts to the rear differential. The TT has six 8 mm allen head bolts, the NA has four 14mm bolts/nuts. In addition, you will need a 17mm socket to remove the bracket for the center support bearing on the stock driveshaft.
You will need to remove the exhaust, at least from the cat back. It can be done by simply disconnecting the rear hangers and letting the exhaust drop a little but it's much easier to just remove the exhaust. Then you will need to remove the heat shield that sits between the exhaust and drive shaft, it's held in place with four 10 mm nuts and two 10 mm bolts.
Once unbolted, slide the front of the shaft out of the trans and install the one piece. If you do not do it quickly a light amount of fluid may leak out of the tailstock of the trans. Once the one piece is in place, torque the drive shaft bolts to 29-33 ft-lbs for the NA drive shaft and 40-47 ft-lbs for the TT.
Put the heat shield and exhaust back in place and you are finished.
This is also a prime time to replace your shifter bushings on a manual trans if they have not been replaced recently.
Hope this helps,Tim
