CrazyS14240 wrote:is their anyway to run a dual 2 ohm voicecoil sub at 2 or 4 ohms, if not im gott atart looking for amps
You can either wire it as a
Series Circuit - A circuit configuration in which a single current path is arranged among all components. Connecting the positive speaker output of an amplifier channel to the positive terminal of speaker # 1 , connecting the negative terminal of # 1 to the positive terminal of speaker # 2, and the negative terminal of # 2 to the negative output of the same amplifier channel is a series connection. NET increases (numeric) ohm load seen by the amplifier.
or
Parallel Circuit - A circuit configuration in which the same voltage is applied to all components, with current divided among the components according to their respective resistances or impedances. Example: All positive leads of two or more speakers connected together and all negative leads connected together. NET decreases (numeric) ohm load seen by the amplifier.
(taken in part from
http://www.the12volt.com)
