1 of 2 Radiator Fans Dead - 2000 I30
sixty4
Car: 2008 QX56
1964 Lincoln Continental
Gone:
2006 QX56, 1998 QX4, 2001 QX4, 2000 I30
I have one of two fans out on my radiator as shown in the photo below. I checked with Advanced Auto who wants about $220 to replace the entire fan assembly which is both fans. This really causes an imbalance and the assembly to make a lot of nice vibrating.
Question #1: Is this a tough job to do on my own? Question#2: Am I right to assume that the fan assembly in all its plastic glory only has electrical contacts and screws to hold it on?
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
Replaced the whole fan assembly (both fans) on my wifes 98 for about $165 parts onlyso your price might not be too bad. You can choose to replace one fanat a time if you want (per Oreillyls parts)
NutriaforBreakfast
It wasnt a hard job to do-everything was very visible to work on. Maybe1 1/2 hr tops.
Plugging in the new fans was most of the work
sixty4
Car: 2008 QX56
Gone:
NutriaforBreakfast wrote:It wasnt a hard job to do-everything was very visible to work on. Maybe1 1/2 hr tops.
Any gotchas on the removal. Per my photo it looks like the fan assembly dissembles from the radiator. How does it fit in there on the bottom side? Are their bolts underneath as well?
NutriaforBreakfast
I was rather suprised how easy it was. I was kind of leary tot but it was ok. There are some boltsbut I dont remember. The FSM should be able to help you.http://www.nicoclub.com/FSM/
sixty4
Car: 2008 QX56
Gone:
Thanks for the info and the FSM, I found the correct page. http://www.nicoclub.com/FSM/i30/2001/lc.pdf
Check this out @ http://www.1aauto.com/1A/Radia...e_api
jwerty1
Car: 08 versa sl cvt blue, 08 frontier se 4x4 kingcab 6sp storm gray
remove 2 10mm screws on top, remove whatever wiring going to the fans, remove the upper rad hose (i believe), and then pull out the fan assy, it just slides into seats that are part of the radiator on the bottom, not bolts on the bottom
sixty4
Car: 2008 QX56
Gone:
Thanks this is great, I can handle this. Any reservaton about the $100 part I listed over Advanced wanting $225?
ruimax
Car: 98 maxima
i have the part out of 98 nissan max both fan 100i am located in new jerseyall you do unplug the radiators 4 screws 2 top 2 bottom
Brandon8965
Car: 1999 Maxima GLE
i actually have the exact same problem with my max right now.. it is an easy fix and shouldn't take that long.. i just don't feel like doin it for the second time lol
sixty4
Car: 2008 QX56
Gone:
Anyone, I am hestitant to buy this at only $100. Should I be concerned or just stick to one with a normal price around $200?
Markc
Car: 2008 m35x
2005 infiniti G35
I don't see a warranty listed. I'd check that out first. But then again for $100 and free shipping with a return policy it seems like a very good deal. I suppose it would cost you ~$40 to ship it back though.My opinion- if I was low on cash, I'd go for it. If I was flush, I'd buy the $200 one.
