pulsar gtr »
https://forums.nicoclub.com/pulsar-gtr-u1034.html
Fri Oct 22, 2004 2:15 pm
Actually, he should of gave more info on his problem.
His problem started when he tried to adjust his timing by turning the CAS, but what I don't understand and I have seen it on different forums including on the SR engine,Is he disconnected his TPS while the car is running and tried to adjust the timing, I haven't seen it any where or seen any one or in the fsm or any where else says to disconnect the TPS while the car is running to adjust the timming.
Any ways, he did that, and the car start stumbling right after.he lives about 3hrs away from me and I paid him a visit a while back.There was some serious wiring mess, and he was using the Euro harness which doesn't have O2 sensor (recently he got a JDM wiring harness and swapped it). So, we swapped the ignitor, CAS, and the coils and the problem stayed there.
The way it sounds is the MAF isn't getting the proper reading or there is some serious vaccum leak after the throttle body as he mentioned that he did the leak test on the intercooler and the piping.
Also, I know he was using some generic sparkplugs and I suggest to use NGK platnium.
Hi Fred, I might be going down to montreal next weekend, if so, I might continue to your place and figure it out.
Any ways, keep me updated.
Thanks,
RafiPULSAR GTR
