Spazz »
https://forums.nicoclub.com/spazz-u19546.html
Tue Jul 31, 2007 5:18 am
easy out is made of High speed steed (HSS) you need either a few tIn coated drills or a tungsten carbide tipped, or sintered carbide tipped drill. or tungsten carbide tipped punch and crack it out.If you try to drill it out again , if you have access to metal coolant , use it , if not, dishsoap and water potentially will work.any carbide tip will make mincemeat out of steel, so be careful.
