Don't switch the injector to another cylinder. Okay so hes running lean and detonating, no need to switch it to another cylinder and grenade that cylinder also. First thing you need to do is to check to see if your injectors are getting the ground pulse from the ECU. Goto a parts store and ask for NOID lights. They are little lights that hook up to the injector harness and light when they are pulsing off of the ECU. take the injector plug off put the noid like in and crank it. If it pulses the next thing to do is to pull the injectors with the rail still connected. Check what wire is ignition power and which is the ECU ground. Then you can quickly TAP that wire to ground and the injector will pulse with the key on. Make sure you have the right wire! Check for 12v power on one of the wires and the other wire will be the ground. After you tap that wire to ground with quick taps look at the spray pattern. If you do not like that method you can have someone lightly tap the key instead, not starting the engine, and look at the spray pattern then. If it does not spray then you have an open in your injector. Take an ohmmeter and ohm the injector out. It should read continuity. If it doesn't the injector is bad.
Kamin wrote:DO NOT APPLY VOLTAGE TO THE INJECTOR you WILL destroy it.
injectors work off very very short electrical pulses, im sure you have heard the term duty cycle, applying straight voltage holds the needle open which frys it.
Injectors do work off of electrical pulses (Duty Cycle) but 12v Ignition power is given to them with the key-on. That does not hurt the injector. It is the GROUND pulse from the ECU that opens them. Grounding them will not hurt them unless you hold it for more than 5 seconds. The timing of the injector is known as "pulse Width" which is how LONG the injector stays open not how much the injectors open. Injectors always open the same amount its the time they stay open that determines how much fuel is given. The injectors practically stay constantly open under WOT, so holding them open won't hurt but I recommend you don't do that anyway.
Try all of that first then get back with us.-Alex
