Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Thu Jun 26, 2008 10:15 am
valve stem leaks typically don't affect compression. the reason why is because the valve has to be sealed against the seat to form a compression seal. You loose compression from the head because something has ruined the seat's sealing surface. This is usually due to the seat being worn down, which usually only alots for a few PSI, a bent/damaged valve, or a damaged seat.
Now, when those go bad, the leaky air goes back into the runners and out either the intake mani or exhaust mani (path of least resistance).
tl;dr, you will not see air come out of the valve cover T due to a leaky valve stem seal
